Salta al contenuto principale
Introduzione
This guide will show you how to remove the keyboard from your laptop.
Parti
Nessuna parte specificata.
  1. Place the laptop facedown with the battery facing you. Push the switch above the battery to the right and hold it in that position. Lift the battery using the grip on the top and remove it from its socket.
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
  2. Open the laptop all the way, rotating the display so that it is level with the surface that you are working on. Insert the spudger underneath the groove on the right side of the hinge cover.
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
  3. Remove the two 5mm JIS #1 screws from the top of the keyboard. Lift the top of the keyboard up and pull the keyboard away from the laptop. Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
  4. Open the latch holding the ribbon from the top Remove the keyboard from the laptop.
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
Conclusione
Don Dao
Membro da: 01/03/2018
301 Reputazione
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 17
Tutti i Tempi: 175
