Salta al contenuto principale
Dell Inspiron 1501 Display Replacement
Cosa ti serve
  1. Dell Inspiron 1501 Display Replacement, Battery: passo 1, immagine 1 di 3 Dell Inspiron 1501 Display Replacement, Battery: passo 1, immagine 2 di 3 Dell Inspiron 1501 Display Replacement, Battery: passo 1, immagine 3 di 3
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
  2. Dell Inspiron 1501 Display Replacement, Hinge Cover: passo 2, immagine 1 di 2 Dell Inspiron 1501 Display Replacement, Hinge Cover: passo 2, immagine 2 di 2
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
  3. Dell Inspiron 1501 Display Replacement, Keyboard: passo 3, immagine 1 di 3 Dell Inspiron 1501 Display Replacement, Keyboard: passo 3, immagine 2 di 3 Dell Inspiron 1501 Display Replacement, Keyboard: passo 3, immagine 3 di 3
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
  4. Dell Inspiron 1501 Display Replacement: passo 4, immagine 1 di 2 Dell Inspiron 1501 Display Replacement: passo 4, immagine 2 di 2
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 1501 Display Replacement, Display: passo 5, immagine 1 di 2 Dell Inspiron 1501 Display Replacement, Display: passo 5, immagine 2 di 2
    • Close display and flip the laptop upside down.
    • Remove the two 8mm JIS #1 screws on the backplate that hold the display.
  6. Dell Inspiron 1501 Display Replacement: passo 6, immagine 1 di 1
    • From the back of the computer, remove the two screw covers.
    • Remove the two 8mm JIS #1 screws.
  7. Dell Inspiron 1501 Display Replacement: passo 7, immagine 1 di 2 Dell Inspiron 1501 Display Replacement: passo 7, immagine 2 di 2
    • Turn the laptop over and open the display.
    • Remove the two 5mm JIS #1 screws on the display hinge.
  8. Dell Inspiron 1501 Display Replacement: passo 8, immagine 1 di 3 Dell Inspiron 1501 Display Replacement: passo 8, immagine 2 di 3 Dell Inspiron 1501 Display Replacement: passo 8, immagine 3 di 3
    • Disconnect the antenna cables from the Mini-Card.
    • Be careful not to knock the standby switch when disconnecting the cables as it is easily broken.
    • Loosen the JIS #1 screw on the display cable.
    • Pull the pull-tab straight up to disconnect the display cable from the laptop.
  9. Dell Inspiron 1501 Display Replacement: passo 9, immagine 1 di 1
    • Remove the display from the rest of the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 828
