Salta al contenuto principale
Dell Inspiron 15-7567 Touchpad Replacement
Cosa ti serve
  1. Dell Inspiron 15-7567 Touchpad  Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 Touchpad  Replacement: passo 2, immagine 1 di 2 Dell Inspiron 15-7567 Touchpad  Replacement: passo 2, immagine 2 di 2
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 Touchpad  Replacement: passo 3, immagine 1 di 1
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 Touchpad  Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15-7567 Touchpad  Replacement: passo 4, immagine 2 di 2
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 Touchpad  Replacement: passo 5, immagine 1 di 2 Dell Inspiron 15-7567 Touchpad  Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 Touchpad  Replacement: passo 6, immagine 1 di 1
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
  7. Dell Inspiron 15-7567 Touchpad  Replacement, Touchpad: passo 7, immagine 1 di 1
    Compra
    • Remove the clip holding the power cord on the Touch Pad by using tweezers, your fingers, or iFixit removing tools to gently pull up on the clip.
    • This should release the power cord as shown.
  8. Dell Inspiron 15-7567 Touchpad  Replacement: passo 8, immagine 1 di 1
    • Remove the four 3mm screws using a Phillips #1 screwdriver in the locations shown.
  9. Dell Inspiron 15-7567 Touchpad  Replacement: passo 9, immagine 1 di 1
    • Remove Touch Pad by pulling towards you gently at a slight upward angle.
    • The Touch Pad is now removed and ready to be replaced.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,988
