Introduzione
In this guide, we will be showing you how to remove and replace the Memory Modules.
Cosa ti serve
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Use the blue, plastic opening tool to gently pry a section of the back panel open.
Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
After the clips have been disconnected, the back panel can then be easily lifted off the computer.
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
Slide and remove the memory module from the memory-module slot.
Align the notch on the NEW memory module with the tab on the memory-module slot.
Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
Altre 2 persone hanno completato questa guida.
