Introduzione
This guide will demonstrate how to replace the keyboard for the Dell Inspiron 15-7559. This may be necessary if you are unable to use the keyboard.
Cosa ti serve
Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
Altre 8 persone hanno completato questa guida.
2 Commenti
How to put it back
Do the steps in reverse order, like it says at the end of the tutorial
