Salta al contenuto principale
Dell Inspiron 15-7559 Display Replacement
Cosa ti serve
  1. Dell Inspiron 15-7559 Display Replacement, Display: passo 1, immagine 1 di 3 Dell Inspiron 15-7559 Display Replacement, Display: passo 1, immagine 2 di 3 Dell Inspiron 15-7559 Display Replacement, Display: passo 1, immagine 3 di 3
    • This next step will likely cause some of the tabs, that hold the display, to snap. They will still function and hold the display in place and there should be no noticeable issues once put back together, but the tabs will have permanent damage and repeated disassembly will most likely require replacement.
    • Using the metal or plastic spudger pry open the frame around the display.
  2. Dell Inspiron 15-7559 Display Replacement: passo 2, immagine 1 di 2 Dell Inspiron 15-7559 Display Replacement: passo 2, immagine 2 di 2
    • Pull the screen down and let it lie on the keyboard.
  3. Dell Inspiron 15-7559 Display Replacement: passo 3, immagine 1 di 3 Dell Inspiron 15-7559 Display Replacement: passo 3, immagine 2 di 3 Dell Inspiron 15-7559 Display Replacement: passo 3, immagine 3 di 3
    • Locate the wire that connects the display to the back panel. There will be a sticker with a qr code on it.
    • Peel the the sticker and pull it back to disconnect the cables.
  4. Dell Inspiron 15-7559 Display Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15-7559 Display Replacement: passo 4, immagine 2 di 2
    • The display is now fully disconnected, you can now completely remove it from the computer.
Conclusione
Altre 4 persone hanno completato questa guida.
UW Tacoma, Team S3-G2, Liner Fall 2017 Membro di UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
5 Membri
9 Guide realizzate
5 Commenti
How do you replace the antenna cables around the display?
Prasanna Pokharel - Replica
There are also six Phillips head screws (size 00) around the screen that have to be removed before you can flip the LCD forward.
Ken Schoenberg - Replica
I encountered 4 phillips screws, and the bezel was slightly different. Did not impact ability to replace screen
Teddy Vandenberg - Replica
This laptop came with 2 screen options. A 1080p non-touch screen, and a 4K touch screen.
The example in this guide is of the 4K touchscreen. The 1080p screen is the display that has the 4 screws and large bezel.
Matthew Parker - Replica
Is it possible to replace a broken 4K screen with a full HD one?
george neverland - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 107
Tutti i Tempi: 14,267
