Salta al contenuto principale
Dell Inspiron 15-7548 Motherboard Replacement
Cosa ti serve
  1. Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: passo 1, immagine 1 di 2 Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Motherboard Replacement: passo 2, immagine 1 di 2 Dell Inspiron 15-7548 Motherboard Replacement: passo 2, immagine 2 di 2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Motherboard Replacement, Motherboard: passo 3, immagine 1 di 1
    • Remove the screws holding the battery.
  4. Dell Inspiron 15-7548 Motherboard Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery ribbon connector.
  5. Dell Inspiron 15-7548 Motherboard Replacement: passo 5, immagine 1 di 1
    • Disconnect the CPU fan ribbon.
  6. Dell Inspiron 15-7548 Motherboard Replacement: passo 6, immagine 1 di 1
    • Disconnect the display screen ribbon connector.
  7. Dell Inspiron 15-7548 Motherboard Replacement: passo 7, immagine 1 di 1
    • Disconnect the blue ribbon connector.
  8. Dell Inspiron 15-7548 Motherboard Replacement: passo 8, immagine 1 di 1
    • Disconnect the blue and gold ribbon connectors.
  9. Dell Inspiron 15-7548 Motherboard Replacement: passo 9, immagine 1 di 1
    • Disconnect the speaker cable.
  10. Dell Inspiron 15-7548 Motherboard Replacement: passo 10, immagine 1 di 1
    • Disconnect the WiFi card connections.
  11. Dell Inspiron 15-7548 Motherboard Replacement: passo 11, immagine 1 di 1
    • Remove the screws securing the heat sink.
  12. Dell Inspiron 15-7548 Motherboard Replacement: passo 12, immagine 1 di 1
    • Remove the heat sink.
  13. Dell Inspiron 15-7548 Motherboard Replacement: passo 13, immagine 1 di 1
    • Remove the motherboard screws.
  14. Dell Inspiron 15-7548 Motherboard Replacement: passo 14, immagine 1 di 1
    • Remove the motherboard.
Conclusione
Michael Nunez
Membro da: 04/12/22
325 Reputazione
2 Guide realizzate
IUPUI, Team 3-3, Beck Spring 2022 Membro di IUPUI, Team 3-3, Beck Spring 2022
IUPUI-BECK-S22S3G3
4 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 558
