Salta al contenuto principale
Dell Inspiron 15-7548 Back Panel Replacement
Cosa ti serve
  1. Dell Inspiron 15-7548 Back Panel Replacement, Back Panel: passo 1, immagine 1 di 2 Dell Inspiron 15-7548 Back Panel Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Back Panel Replacement: passo 2, immagine 1 di 2 Dell Inspiron 15-7548 Back Panel Replacement: passo 2, immagine 2 di 2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,002
