Salta al contenuto principale
Dell Inspiron 15-7548 Battery Replacement
Cosa ti serve
  1. Dell Inspiron 15-7548  Battery Replacement, Back Panel: passo 1, immagine 1 di 2 Dell Inspiron 15-7548  Battery Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548  Battery Replacement: passo 2, immagine 1 di 2 Dell Inspiron 15-7548  Battery Replacement: passo 2, immagine 2 di 2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548  Battery Replacement, Battery: passo 3, immagine 1 di 2 Dell Inspiron 15-7548  Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
  4. Dell Inspiron 15-7548  Battery Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15-7548  Battery Replacement: passo 4, immagine 2 di 2
    • Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
Conclusione
Altre 4 persone hanno completato questa guida.
Un commento
Little grey piece on the cable popped off, will that affect anything? Laptop isn’t recognizing that it has a battery after I took it out and put it back in.
Taylor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 2,486
