Salta al contenuto principale
Dell Inspiron 15-7547 WiFi Card Replacement
Cosa ti serve
  1. Dell Inspiron 15-7547 WiFi Card Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 WiFi Card Replacement: passo 2, immagine 1 di 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 WiFi Card Replacement, WiFi Card: passo 3, immagine 1 di 2 Dell Inspiron 15-7547 WiFi Card Replacement, WiFi Card: passo 3, immagine 2 di 2
    • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
  4. Dell Inspiron 15-7547 WiFi Card Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15-7547 WiFi Card Replacement: passo 4, immagine 2 di 2
    • Remove the Wifi-Card from its socket by pulling away and up from the connector.
  5. Dell Inspiron 15-7547 WiFi Card Replacement: passo 5, immagine 1 di 2 Dell Inspiron 15-7547 WiFi Card Replacement: passo 5, immagine 2 di 2
    • Disconnect the white and black cables from the Wifi-Card.
    • Make a note of which wire goes where for reconnecting them to the replacement card.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 322
