Salta al contenuto principale
Dell Inspiron 15-7547 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 15-7547 Hard Drive Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 2 Dell Inspiron 15-7547 Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 2
    • Remove the four 5.0 mm-long Philips #0 screws connecting the hard drive to the chassis.
  4. Dell Inspiron 15-7547 Hard Drive Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15-7547 Hard Drive Replacement: passo 4, immagine 2 di 2
    • Disconnect the hard drive from the motherboard by placing your fingers at the back, and pulling forward towards the front of the chassis.
  5. Dell Inspiron 15-7547 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Lift the hard drive out of the chassis.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 747
