Salta al contenuto principale
Dell Inspiron 15-7547 CPU Fan Replacement
Cosa ti serve
  1. Dell Inspiron 15-7547 CPU Fan Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 CPU Fan Replacement: passo 2, immagine 1 di 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 CPU Fan Replacement, CPU Fan: passo 3, immagine 1 di 2 Dell Inspiron 15-7547 CPU Fan Replacement, CPU Fan: passo 3, immagine 2 di 2
    • Remove the two 5.0 mm-long Philips #0 screws from the fan.
    • The screw marked in orange will remain captive to the fan.
  4. Dell Inspiron 15-7547 CPU Fan Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15-7547 CPU Fan Replacement: passo 4, immagine 2 di 2
    • Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
  5. Dell Inspiron 15-7547 CPU Fan Replacement: passo 5, immagine 1 di 1
    • Lift the fan out of the chassis.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 523
