Salta al contenuto principale
Dell Inspiron 15-7547 Bottom Cover Replacement
Cosa ti serve
  1. Dell Inspiron 15-7547 Bottom Cover Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Bottom Cover Replacement: passo 2, immagine 1 di 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 4,477
