Salta al contenuto principale
Dell Inspiron 15-7537 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 15-7537 Keyboard Replacement, Bottom Case: passo 1, immagine 1 di 1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Keyboard Replacement: passo 3, immagine 1 di 1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Keyboard Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
  5. Dell Inspiron 15-7537 Keyboard Replacement: passo 5, immagine 1 di 1
    • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
    • Using the pull tab on the battery, lift the battery out of the computer.
  6. Dell Inspiron 15-7537 Keyboard Replacement, Removing the Keyboard: passo 6, immagine 1 di 1
    • Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
  7. Dell Inspiron 15-7537 Keyboard Replacement: passo 7, immagine 1 di 1
    • Flip over the computer and open the display as far as it can go.
    • Use the spudger to remove the keyboard from the palm assembly.
  8. Dell Inspiron 15-7537 Keyboard Replacement: passo 8, immagine 1 di 1
    • Gently flip over the keyboard and place it on the palm rest assembly.
    • Lift the connector latches and disconnect the keyboard and the keyboard back-light cables.
  9. Dell Inspiron 15-7537 Keyboard Replacement: passo 9, immagine 1 di 3 Dell Inspiron 15-7537 Keyboard Replacement: passo 9, immagine 2 di 3 Dell Inspiron 15-7537 Keyboard Replacement: passo 9, immagine 3 di 3
    • Take the keyboard off the palm rest assembly.
Conclusione
Altre 11 persone hanno completato questa guida.
Cal Poly, Team 18-2, Maness Winter 2015 Membro di Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Membri
8 Guide realizzate
3 Commenti
Great guide, thanks for the help!
Patrick S - Replica
Thanks It’s Useful
ahmed omar - Replica
It is important to note that the little black clips on the ends of the keyboard wires SWIVEL UP! I broke mine because nothing in this guide told me how to get the wires out properly.
benton.addison - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 32
Tutti i Tempi: 6,647
