Salta al contenuto principale
Introduzione
In this guide, we will be showing you how to remove and replace the Memory Modules.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer.  After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  2. Remove the memory module from the memory-module slot.
    • Remove the memory module from the memory-module slot.
  3. Align the notch on the NEW memory module with the tab on the memory-module slot.
    • Align the notch on the NEW memory module with the tab on the memory-module slot.
  4. Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Linea Traguardo
Terrence15
Membro da: 18/12/2017
71.356 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
926 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 285
