Introduzione
Removing the back cover is a fundamental step for cleaning, replacing, or repairing many other components inside the laptop. That’s why this will serve as a pre-requisite task for most of the replacement guides of the Dell Inspiron 15-5567. You will only need a Philips #0 screwdriver and the blue plastic opening tool to complete this guide.
Cosa ti serve
Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
Remove two M2x4mm screws using the same screwdriver.
Altre 4 persone hanno completato questa guida.
