Introduzione
This guide will assist you in efficiently replacing the memory modules (also known as RAM) in your Dell Inspiron 15-5565. Please see this page to perform troubleshooting.
Some common identifying factors that indicate RAM replacement is needed include the Blue Screen of Death, random reboots, and overall decline in device performance.
Specifications:
- Two SODIMM slots
- Single or Dual-channel DDR4
Cosa ti serve
Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
Use your fingers to pull the safety clips apart on either side of the memory module. This should make the module pop upwards.
Remove the module from its slot by pulling it out.
