Salta al contenuto principale
Dell Inspiron 15-5565 Coin Cell Battery Replacement
Cosa ti serve
  1. Dell Inspiron 15-5565 Coin Cell Battery Replacement, Optical Drive: passo 1, immagine 1 di 1
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 Coin Cell Battery Replacement: passo 2, immagine 1 di 3 Dell Inspiron 15-5565 Coin Cell Battery Replacement: passo 2, immagine 2 di 3 Dell Inspiron 15-5565 Coin Cell Battery Replacement: passo 2, immagine 3 di 3
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 Coin Cell Battery Replacement, Back Cover: passo 3, immagine 1 di 2 Dell Inspiron 15-5565 Coin Cell Battery Replacement, Back Cover: passo 3, immagine 2 di 2
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 Coin Cell Battery Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15-5565 Coin Cell Battery Replacement: passo 4, immagine 2 di 2
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 Coin Cell Battery Replacement, Coin Cell Battery: passo 5, immagine 1 di 3 Dell Inspiron 15-5565 Coin Cell Battery Replacement, Coin Cell Battery: passo 5, immagine 2 di 3 Dell Inspiron 15-5565 Coin Cell Battery Replacement, Coin Cell Battery: passo 5, immagine 3 di 3
    • Remove the coin-cell battery by carefully pulling the plug from the slot.
    • The coin-cell battery is simply plugged into the circuitry. No screws or tools are needed.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 29
Tutti i Tempi: 269
