Salta al contenuto principale
Dell Inspiron 15-5559 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: passo 1, immagine 1 di 2 Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: passo 1, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
  2. Dell Inspiron 15-5559 Hard Drive Replacement: passo 2, immagine 1 di 2 Dell Inspiron 15-5559 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off.
    • Do not be afraid to use a bit of muscle, as the panel does not come off without some force.
  3. Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 3 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 3 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: passo 3, immagine 3 di 3
    • Remove each of the four (4) 2.5x8mm screws that anchor the hard drive using a Phillips #1 screwdriver.
  4. Dell Inspiron 15-5559 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Use the plastic spudger to remove the hard drive conductive tape by lifting the black clasp holding it down, then pulling the conductive tape toward the left to remove it.
    • It does not take much force to remove the conductive tape. Remove it gently so that you do not damage it.
  5. Dell Inspiron 15-5559 Hard Drive Replacement: passo 5, immagine 1 di 2 Dell Inspiron 15-5559 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Place the plastic spudger underneath the hard drive at the indicated position.
    • Use the spudger along with your other hand to gently remove the hard drive.
Conclusione
Altre 4 persone hanno completato questa guida.
Kyla Ward
Membro da: 03/19/18
580 Reputazione
4 Guide realizzate
Baylor, Team S5-G5, Williams Spring 2018 Membro di Baylor, Team S5-G5, Williams Spring 2018
BU-WILLIAMS-S18S5G5
3 Membri
5 Guide realizzate
2 Commenti
The blue part came off is that important?
walterandradeconde - Replica
can i put this in a harddrive enclosure?
chiggly 123 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 5,177
