Salta al contenuto principale
Dell Inspiron 15-5558 RAM Replacement
Cosa ti serve
  1. Dell Inspiron 15-5558 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 RAM Replacement: passo 2, immagine 1 di 1
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 RAM Replacement: passo 3, immagine 1 di 2 Dell Inspiron 15-5558 RAM Replacement: passo 3, immagine 2 di 2
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 RAM Replacement, Hard Drive: passo 4, immagine 1 di 3 Dell Inspiron 15-5558 RAM Replacement, Hard Drive: passo 4, immagine 2 di 3 Dell Inspiron 15-5558 RAM Replacement, Hard Drive: passo 4, immagine 3 di 3
    • Using a Phillips #0 screwdriver, unscrew the two 8mm screws from the panel.
    • Take a spudger and wedge it between the panel and the base of the device.
    • Push down on the spudger until you hear a click sound.
    • Slide the spudger along the panel and continue to push down until the panel is completely detached.
    • Remove the panel.
  5. Dell Inspiron 15-5558 RAM Replacement: passo 5, immagine 1 di 3 Dell Inspiron 15-5558 RAM Replacement: passo 5, immagine 2 di 3 Dell Inspiron 15-5558 RAM Replacement: passo 5, immagine 3 di 3
    • Using the Phillips #0 screwdriver, remove the four 8mm screws holding down the hard drive.
    • Take the spudger and prop up the connector so it is no longer attached.
    • Use the spudger and prop up the hard drive and remove it.
  6. Dell Inspiron 15-5558 RAM Replacement, RAM: passo 6, immagine 1 di 3 Dell Inspiron 15-5558 RAM Replacement, RAM: passo 6, immagine 2 di 3 Dell Inspiron 15-5558 RAM Replacement, RAM: passo 6, immagine 3 di 3
    • Locate the two RAM cards.
    • Using your finger, pull the two small pins back from the RAM causing it to pop up.
  7. Dell Inspiron 15-5558 RAM Replacement: passo 7, immagine 1 di 1
    • Once popped up, pull the ram out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,381
