Salta al contenuto principale
Dell Inspiron 15-5558 Palm-Rest Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Eject CD Tray and Turn Off Laptop: passo 1, immagine 1 di 2 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Eject CD Tray and Turn Off Laptop: passo 1, immagine 2 di 2
    • Eject the CD tray while the laptop is on.
    • Turn off the laptop using the power button.
    • Or remove the 2x5 securing screw and push through the battery compartment to slide the optical drive out.
  2. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Battery Removal: passo 2, immagine 1 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Battery Removal: passo 2, immagine 2 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Battery Removal: passo 2, immagine 3 di 3
    • Make sure that the laptop is turned off before proceeding.
    • Move the unlocking switch to the left to eject the battery.
    • The battery is designed to rotate slightly before lifting out.
    • Remove the 2.5x5 screws inside the compartment.
  3. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Keyboard Removal: passo 3, immagine 1 di 2 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Keyboard Removal: passo 3, immagine 2 di 2
    • Turn the laptop over and open up the front screen to show the keyboard.
    • Use a (Philips) flathead near the top, center of the keyboard to begin popping out the keyboard.
    • Push straight down on the securing clips and they will move towards the screen - away from the top of the keyboard.
    • You may also use your hands once you begin the process.
    • Remove the bottom tabs of the keyboard by pulling the keyboard up towards the screen.
  4. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Keyboard Disconnection: passo 4, immagine 1 di 2 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Keyboard Disconnection: passo 4, immagine 2 di 2
    • Carefully lift up the keyboard
    • There should be cables hooked to underside of the keyboard.
    • Remove tape, if there is tape, and disconnect all flaps and cables by lifting up.
  5. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Disconnect Cables: passo 5, immagine 1 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Disconnect Cables: passo 5, immagine 2 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Disconnect Cables: passo 5, immagine 3 di 3
    • Remove all connected cables by pulling the black tapes up to unlock each cable.
    • To reconnect the cables, align and place the end of a cable into the slot of the black tab. Then push the black tab down to lock the cable in place.
  6. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Base Cover Removal: passo 6, immagine 1 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Base Cover Removal: passo 6, immagine 2 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Base Cover Removal: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Compra
    • Use Phillips #00 screwdriver to remove 2.5 x 8 screws securing the base cover.
    • Use the 3/32 Flathead screwdriver to gently pry off the base cover around the top , slotted section .
  7. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Hard Drive Removal: passo 7, immagine 1 di 2 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Hard Drive Removal: passo 7, immagine 2 di 2
    • Remove screws securing the hard drive to the laptop.
    • Disconnect the black cable by pulling it away from the hard drive.
    • Lift the black latch to unlock the cable.
    • Remove the hard drive cable from the lower, blue circuit board
    • Remove the hard drive from the laptop.
    • Or, unlatching the cable lets you keep the black adapter attached to the hard drive to remove as one unit.
    • My latch was white and it rotates in the black base.
  8. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Wireless Card Removal: passo 8, immagine 1 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Wireless Card Removal: passo 8, immagine 2 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Wireless Card Removal: passo 8, immagine 3 di 3
    • Unscrew the M2x3 screw
    • Note how the bracket covers the antenna leads. There is a small tab on the bracket to keep it aligned.
    • Lift off wireless card bracket
    • Gently unplug the wireless card by pulling it out to the left
    • Disconnect the black and white antenna cables
    • Remember when re-assembling this item to plug in the white cable to the lower plug and the black cable to the higher plug.
  9. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement: passo 9, immagine 1 di 2 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement: passo 9, immagine 2 di 2
    • Remove the screws securing the palmrest and base.
    • Note the panhead screws securing the base in the optical drive opening.
    • Use the Philips flathead and your hands to lift up the computer base.
    • Bits of plastic tabs may break off.
    • Be careful to lift up the keyboard around the hinges.
  10. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Remove the Speakers: passo 10, immagine 1 di 2 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Remove the Speakers: passo 10, immagine 2 di 2
    • The speakers may be removed from the computer base by unattaching from the computer base or disconnecting the cable and leaving the speakers on the computer base.
  11. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Remove the Optical Drive Assembly: passo 11, immagine 1 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Remove the Optical Drive Assembly: passo 11, immagine 2 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Remove the Optical Drive Assembly: passo 11, immagine 3 di 3
    • Disconnect the optical drive cable that is attached to the innermost layer of computer components.
    • While lifting up, unscrew all screws holding the optical drive to the computer base.
    • Remove the optical drive assembly
  12. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Remove I/O Board: passo 12, immagine 1 di 2 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Remove I/O Board: passo 12, immagine 2 di 2
    • Unscrew the two screws securing the I/O Board to the laptop.
    • Remove the I/O board
  13. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Left and Right Hinges: passo 13, immagine 1 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Left and Right Hinges: passo 13, immagine 2 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Left and Right Hinges: passo 13, immagine 3 di 3
    • Unscrew all screws securing the left and right hinges.
    • Lift the hinges up towards the screen to expose the lower components.
    • The lift hinge when facing the laptop towards the screen has a circuit board under the hinge. This should be removed after taking out the screws.
    • If a golden threaded screw component breaks off the plastic base, use pilers to hold the component while unscrewing the screw to remove the screw.
  14. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Remove Motherboard and Heatsink: passo 14, immagine 1 di 2 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Remove Motherboard and Heatsink: passo 14, immagine 2 di 2
    • Unscrew the following screws from the motherboard and heatsink.
    • Disconnect the power button cable.
    • Lift from the laptop the motherboard and the heatsink assembly.
  15. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Remove Screen: passo 15, immagine 1 di 1
    • Remove the screen from the lower assembly by lifting it up from the now disconnected right and left hinges.
  16. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Remove the Mousepad: passo 16, immagine 1 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Remove the Mousepad: passo 16, immagine 2 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Remove the Mousepad: passo 16, immagine 3 di 3
    • Take off the two gold pieces of tape.
    • Unscrew the circuit board near the left hinge, when looking at the laptop from the front. (This is connected to the mousepad)
    • Remove tape and lift off the black and white antenna cables starting at the mousepad to the left hinge.
    • Take off the tan golden tape.
    • From the back, pop out the mousepad from the assembly. Be careful to lift out the tabs correctly.
  17. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Replace the Palm-Rest Assembly: passo 17, immagine 1 di 1
    • Remove the original palm-rest assembly component from the laptop
    • Get out the replacement palm-rest assembly component.
    • From this step onward, use the new replacement palm-rest assembly component.
  18. Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Attach the Mousepad: passo 18, immagine 1 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Attach the Mousepad: passo 18, immagine 2 di 3 Dell Inspiron 15-5558 Palm-Rest Assembly Replacement, Attach the Mousepad: passo 18, immagine 3 di 3
    • Fit the mousepad into the new palm-rest assembly component from the front of the laptop
    • Make sure to fit the cables through the back.
    • Put golden tape back on.
    • Adjust the cable for the mousepad back through slots on the internal side of the palm-rest assembly
Conclusione
To reassemble your device, follow these instructions in reverse order with the new replacement palm-rest assembly component.
Altre 4 persone hanno completato questa guida.
KES Company
Membro da: 12/02/19
368 Reputazione
1 Guida realizzata
KES Company Membro di KES Company
Community
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,727
