Salta al contenuto principale
Dell Inspiron 15-5558 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 15-5558 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Keyboard Replacement: passo 2, immagine 1 di 1
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Keyboard Replacement: passo 3, immagine 1 di 2 Dell Inspiron 15-5558 Keyboard Replacement: passo 3, immagine 2 di 2
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 3 Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: passo 4, immagine 2 di 3 Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: passo 4, immagine 3 di 3
    • Identify the two small slots along the side of the keyboard closest to the screen.
    • Wedge the spudger in the two small slots and push the spudger in and down to detach the pins.
    • Using your hands, pull the keyboard up and out.
  5. Dell Inspiron 15-5558 Keyboard Replacement: passo 5, immagine 1 di 3 Dell Inspiron 15-5558 Keyboard Replacement: passo 5, immagine 2 di 3 Dell Inspiron 15-5558 Keyboard Replacement: passo 5, immagine 3 di 3
    • At the end of the ribbon cable attaching the keyboard to the device is a bar secure.
    • Using your finger or spudger, flip the bar up and the keyboard will be freed from the device.
Conclusione
Altre 5 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,861
