Salta al contenuto principale
Dell Inspiron 15-5558 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 15-5558 Display Assembly Replacement, Note the Antenna Cable: passo 1, immagine 1 di 1
  2. Dell Inspiron 15-5558 Display Assembly Replacement, Disconnecting the Display Cable: passo 2, immagine 1 di 2 Dell Inspiron 15-5558 Display Assembly Replacement, Disconnecting the Display Cable: passo 2, immagine 2 di 2
    • Lift the latch and disconnect the display cable from the system board.
  3. Dell Inspiron 15-5558 Display Assembly Replacement, Note the Display Cable: passo 3, immagine 1 di 1
    • Note the display cable routing and remove the cable from its routing guides.
  4. Dell Inspiron 15-5558 Display Assembly Replacement, Turn the Computer Over: passo 4, immagine 1 di 1
    • Turn the computer over.
    • Open the display at an angle of 90 degrees.
  5. Dell Inspiron 15-5558 Display Assembly Replacement, Placing the Computer: passo 5, immagine 1 di 1
    • Place the computer on the edge of the table so that the palm-rest assembly is on the table and the display assembly extends past the table edge with the display hinges facing up.
  6. Dell Inspiron 15-5558 Display Assembly Replacement, Remove the Screws: passo 6, immagine 1 di 1
    • Remove the screws that secure the display hinges to the palm-rest assembly.
  7. Dell Inspiron 15-5558 Display Assembly Replacement, Lifting the Display Assembly: passo 7, immagine 1 di 1
    • Lift the display assembly off the palm-rest assembly.
  8. Dell Inspiron 15-5558 Display Assembly Replacement, Placing the Palm Rest Assembly: passo 8, immagine 1 di 1
    • Place the palm-rest assembly at the edge of the table with the coin-cell battery facing away from the edge.
  9. Dell Inspiron 15-5558 Display Assembly Replacement, Align the Screw Holes: passo 9, immagine 1 di 1
    • Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  10. Dell Inspiron 15-5558 Display Assembly Replacement, Replace the Screws: passo 10, immagine 1 di 1
    • Replace the screws that secure the display hinges to the palm-rest assembly.
  11. Dell Inspiron 15-5558 Display Assembly Replacement, Route the Display Cable: passo 11, immagine 1 di 1
    • Close the display and turn the computer over.
    • Route the display cable through the routing guides on the palm-rest assembly.
  12. Dell Inspiron 15-5558 Display Assembly Replacement, Slide the Display Cable: passo 12, immagine 1 di 1
    • Slide the display cable to the connector and press down on the latch to connect the display cable to the system board.
  13. Dell Inspiron 15-5558 Display Assembly Replacement, Routing the Antenna Cable: passo 13, immagine 1 di 1
    • Route the antenna cable through the routing guides on the palm-rest assembly.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,892
