Salta al contenuto principale
Dell Inspiron 15-5552 Memory Replacement
Cosa ti serve
  1. Dell Inspiron 15-5552 Memory Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Memory Replacement: passo 2, immagine 1 di 1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Memory Replacement: passo 3, immagine 1 di 1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Memory Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15-5552 Memory Replacement: passo 4, immagine 2 di 2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 Memory Replacement, Screw Location: passo 5, immagine 1 di 1
    • Flip the device on its back, locate the screws circled.
  6. Dell Inspiron 15-5552 Memory Replacement, Screw Removal: passo 6, immagine 1 di 1
    • Use a J0 screwdriver to unscrew the two, 6mm Phillips screw on the rear-cover.
  7. Dell Inspiron 15-5552 Memory Replacement, Removing Cover: passo 7, immagine 1 di 3 Dell Inspiron 15-5552 Memory Replacement, Removing Cover: passo 7, immagine 2 di 3 Dell Inspiron 15-5552 Memory Replacement, Removing Cover: passo 7, immagine 3 di 3
    • Using a spudger, Lightly lift the rear-cover up and at an angle, away from the computer.
  8. Dell Inspiron 15-5552 Memory Replacement, RAM Removal: passo 8, immagine 1 di 2 Dell Inspiron 15-5552 Memory Replacement, RAM Removal: passo 8, immagine 2 di 2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  9. Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: passo 9, immagine 1 di 2 Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: passo 9, immagine 2 di 2
    • Remove the dislodged up RAM by pulling it away from the connection.
    • If it does not pop up, pry it out in a steady and straight direction.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 294
