Salta al contenuto principale
Dell Inspiron 15-5552 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 15-5552 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Keyboard Replacement: passo 2, immagine 1 di 1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Keyboard Replacement: passo 3, immagine 1 di 1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Keyboard Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15-5552 Keyboard Replacement: passo 4, immagine 2 di 2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 Keyboard Replacement, Keyboard: passo 5, immagine 1 di 2 Dell Inspiron 15-5552 Keyboard Replacement, Keyboard: passo 5, immagine 2 di 2
    • Keyboard
    • Insert a spudger next to the 5 plastic indents located at the top of the keyboard and gently pry to release the securing clips.
  6. Dell Inspiron 15-5552 Keyboard Replacement: passo 6, immagine 1 di 2 Dell Inspiron 15-5552 Keyboard Replacement: passo 6, immagine 2 di 2
    • Lift the keyboard off of the computer. *Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.*
  7. Dell Inspiron 15-5552 Keyboard Replacement: passo 7, immagine 1 di 1
    • Flip the keyboard over onto the palm-rest assembly.
  8. Dell Inspiron 15-5552 Keyboard Replacement: passo 8, immagine 1 di 2 Dell Inspiron 15-5552 Keyboard Replacement: passo 8, immagine 2 di 2
    • Flip the black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
Conclusione
Un commento
After reading this it took all of 5 minutes to remove the key board thank you now to see why this computer will not power up!!!
Ronald Giles - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 251
