Salta al contenuto principale
Dell Inspiron 15-5552 Battery Replacement
Cosa ti serve
  1. Dell Inspiron 15-5552 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Battery Replacement: passo 2, immagine 1 di 1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Battery Replacement: passo 3, immagine 1 di 1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Battery Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15-5552 Battery Replacement: passo 4, immagine 2 di 2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 254
