Salta al contenuto principale
Dell Inspiron 15-5548 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 15-5548 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 Dell Inspiron 15-5548 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 Dell Inspiron 15-5548 Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Open up the front of the laptop.
    • Locate the 5 holes at the top of the keyboard, as circled in Picture 2.
    • Use the metal spudger to pry up the keyboard at each of the 5 points.
    • This may take some extra force, and it should pop when it is pried off.
  2. Dell Inspiron 15-5548 Keyboard Replacement: passo 2, immagine 1 di 3 Dell Inspiron 15-5548 Keyboard Replacement: passo 2, immagine 2 di 3 Dell Inspiron 15-5548 Keyboard Replacement: passo 2, immagine 3 di 3
    • When all the points have been pried up, gently lift the keyboard.
    • Lift the ZIF tabs holding down the two ribbon cables, and gently remove them.
    • Remove the keyboard.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,615
