Salta al contenuto principale
Dell Inspiron 15-5547 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Use the Jimmy to pry and detach the keyboard from the laptop at the following locations.
    • Lift the keyboard from the top and gently detach it from the bottom end.
    • Be careful not to pull too quickly in order to avoid damage to the keyboard connector ribbon cables.
  2. Dell Inspiron 15-5547 Keyboard Replacement: passo 2, immagine 1 di 2 Dell Inspiron 15-5547 Keyboard Replacement: passo 2, immagine 2 di 2
    • Detach the smaller ribbon cable from the laptop connector base by gently pulling upward on the connector base. This will free the ribbon cable.
    • Detach the larger ribbon cable from the laptop connector base in the same manner as the first. This will completely detach the keyboard from the laptop.
    • Be careful when detaching and removing the ribbon cables so as not to tear or damage them.
Conclusione
Altre 4 persone hanno completato questa guida.
Faiq Huzir
Membro da: 05/22/19
121 Reputazione
1 Guida realizzata
IUPUI, Team S1-G3, Harley Summer 2019 Membro di IUPUI, Team S1-G3, Harley Summer 2019
IUPUI-HARLEY-SU19S1G3
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 833
