Salta al contenuto principale
Dell Inspiron 15-5547 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 15-5547 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Flip the laptop on its top so that the back is facing up as seen in the picture.
    • Using a Phillips #0 screwdriver, remove the two screws.
  2. Dell Inspiron 15-5547 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Using an iFixit Opening Tool, pry open the back panel through the small notch.
  3. Dell Inspiron 15-5547 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the four screws securing the hard drive.
  4. Dell Inspiron 15-5547 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Lift the hard drive out of the dock and unplug from the motherboard.
    • Be careful so as to not damage the cable.
  5. Dell Inspiron 15-5547 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Using a Phillips #0 screwdriver, unscrew the four screws located on the side of the chassis to free the hard drive from the bracket.
    • Remove the hard drive from the bracket.
Conclusione
Nicholas Nafziger
Membro da: 11/04/19
266 Reputazione
2 Guide realizzate
IUPUI, Team S1-G2, Harley Fall 2019 Membro di IUPUI, Team S1-G2, Harley Fall 2019
IUPUI-HARLEY-F19S1G2
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,376
