Salta al contenuto principale
Dell Inspiron 15-3543 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Turn the device over and open it.
    • You will see 5 notches at the top of the keyboard.
    • Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
  2. Dell Inspiron 15-3543 Keyboard Replacement: passo 2, immagine 1 di 2 Dell Inspiron 15-3543 Keyboard Replacement: passo 2, immagine 2 di 2
    • Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
    • Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
  3. Dell Inspiron 15-3543 Keyboard Replacement: passo 3, immagine 1 di 2 Dell Inspiron 15-3543 Keyboard Replacement: passo 3, immagine 2 di 2
    • To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
    • After popping up the ribbon cable lock, you can pull the ribbon cable out.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Thanks. Could you please suggest a recommended replacement keyboard? I didn't find any branded replacement item in Amazon.
Arun Prasad - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,195
