Salta al contenuto principale
Dell Inspiron 15-3542 LCD Screen Replacement
Cosa ti serve
  1. Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 3 Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 3 Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: passo 1, immagine 3 di 3
    • Power off the laptop.
    • Flip the laptop over so the bottom is facing up.
    • Slide the right button to the unlock symbol.
    • Slide the left button to the other unlock symbol.
    • While holding the left button, use your right finger to raise the battery up from the laptop.
  2. Dell Inspiron 15-3542 LCD Screen Replacement: passo 2, immagine 1 di 3 Dell Inspiron 15-3542 LCD Screen Replacement: passo 2, immagine 2 di 3 Dell Inspiron 15-3542 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Flip the laptop over so the top is facing up and open the laptop.
    • Using both hands, unsnap the tabs around the perimeter of the bezel and remove it from the laptop.
  3. Dell Inspiron 15-3542 LCD Screen Replacement: passo 3, immagine 1 di 3 Dell Inspiron 15-3542 LCD Screen Replacement: passo 3, immagine 2 di 3 Dell Inspiron 15-3542 LCD Screen Replacement: passo 3, immagine 3 di 3
    • Remove the four screws from the corners of the LCD using a Phillips screwdriver.
    • Lift the screen up and place it on the keyboard.
  4. Dell Inspiron 15-3542 LCD Screen Replacement: passo 4, immagine 1 di 3 Dell Inspiron 15-3542 LCD Screen Replacement: passo 4, immagine 2 di 3 Dell Inspiron 15-3542 LCD Screen Replacement: passo 4, immagine 3 di 3
    • Gently peel off the yellow clear tape securing the video connector.
    • Use an opening tool to flip open the video connector bracket.
    • Make sure not to force the video cable when removing it from the connector bracket.
    • Disconnect the cable from the LCD screen and remove the LCD from the laptop.
Conclusione
Najeemdeen Lamidi
Membro da: 09/19/20
130 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,084
