Salta al contenuto principale
Dell Inspiron 15-3531 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 15-3531 Hard Drive Replacement, Battery: passo 1, immagine 1 di 3 Dell Inspiron 15-3531 Hard Drive Replacement, Battery: passo 1, immagine 2 di 3 Dell Inspiron 15-3531 Hard Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 3 Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: passo 2, immagine 2 di 3 Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: passo 2, immagine 3 di 3
    • Loosen the two screws on the access panel using the PH1 head screwdriver.
    • Pry the access panel from the laptop using the spudger.
  3. Dell Inspiron 15-3531 Hard Drive Replacement: passo 3, immagine 1 di 2 Dell Inspiron 15-3531 Hard Drive Replacement: passo 3, immagine 2 di 2
    • Lift the access panel away from the laptop to reveal the hard drive on the left.
    • Remove the two 8.65 mm screws on the left side of the hard drive using the PH0 head screwdriver.
    • There is a plastic tab beneath the hard drive.
  4. Dell Inspiron 15-3531 Hard Drive Replacement: passo 4, immagine 1 di 3 Dell Inspiron 15-3531 Hard Drive Replacement: passo 4, immagine 2 di 3 Dell Inspiron 15-3531 Hard Drive Replacement: passo 4, immagine 3 di 3
    • Push the hard drive to the left to release it and use the tab to pull it free from the laptop. The hard drive is in a caddy.
    • Remove the two 1.22 mm screws holding the hard drive in the caddy with the PH0 head screwdriver.
Conclusione
Kody Dahlke
Membro da: 02/15/18
730 Reputazione
5 Guide realizzate
USF Tampa, Team S1-G5, Leahy Spring 2018 Membro di USF Tampa, Team S1-G5, Leahy Spring 2018
USFT-LEAHY-S18S1G5
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 997
