Salta al contenuto principale
Dell Inspiron 15-3521 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 15-3521 Keyboard Replacement, Remove the Battery: passo 1, immagine 1 di 3 Dell Inspiron 15-3521 Keyboard Replacement, Remove the Battery: passo 1, immagine 2 di 3 Dell Inspiron 15-3521 Keyboard Replacement, Remove the Battery: passo 1, immagine 3 di 3
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Keyboard Replacement, Removing Keyboard: passo 2, immagine 1 di 3 Dell Inspiron 15-3521 Keyboard Replacement, Removing Keyboard: passo 2, immagine 2 di 3 Dell Inspiron 15-3521 Keyboard Replacement, Removing Keyboard: passo 2, immagine 3 di 3
    • Flip laptop right side up
    • Using a flat head screwdriver, depress locking tabs holding keyboard into place
    • Using a spudger, pry the keyboard from the laptop, giving room to access with hands.
    • Using hands, remove keyboard completely from laptop body, leaving only the connecting cord that attaches the keyboard to the laptop.
  3. Dell Inspiron 15-3521 Keyboard Replacement, Disconnecting the Keyboard Cable: passo 3, immagine 1 di 3 Dell Inspiron 15-3521 Keyboard Replacement, Disconnecting the Keyboard Cable: passo 3, immagine 2 di 3 Dell Inspiron 15-3521 Keyboard Replacement, Disconnecting the Keyboard Cable: passo 3, immagine 3 di 3
    • To disconnect the keyboard, locate the keyboard cable locking mechanism.
    • Open the locking mechanism by gently pulling up.
    • Slide out the keyboard cable from the interface to separate the keyboard form the laptop.
Conclusione
Altre 13 persone hanno completato questa guida.
Andrew Dippre
Membro da: 10/13/14
2.902 Reputazione
7 Guide realizzate
Clemson, Team 3-1, Benson Fall 2014 Membro di Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 Membri
9 Guide realizzate
Un commento
Awesome post. Thanks
Derek Morgan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 54
Tutti i Tempi: 22,395
