Salta al contenuto principale
Dell Inspiron 15 Ram (Memory Module) Replacement
Cosa ti serve
  1. Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 Ram (Memory Module) Replacement: passo 2, immagine 1 di 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): passo 3, immagine 1 di 3 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): passo 3, immagine 2 di 3 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): passo 3, immagine 3 di 3
    • Remove the bottom cover by removing the 4 mm screw using a PH-0 Phillips screwdriver that secures the base cover to the laptop base.
    • Using the plastic opening tool, pry the base cover from the base.
    • Slide the base cover towards you and remove it from the base. Put it aside.
  4. Dell Inspiron 15 Ram (Memory Module) Replacement: passo 4, immagine 1 di 3 Dell Inspiron 15 Ram (Memory Module) Replacement: passo 4, immagine 2 di 3 Dell Inspiron 15 Ram (Memory Module) Replacement: passo 4, immagine 3 di 3
    • Using your fingertips, pry the vertical sides of the memory module apart until the piece pops out of place.
    • Slide the memory module out of its slot and lift it out of the laptop base.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 38
Tutti i Tempi: 6,344
