Introduzione
In this guide, we will be showing you how to remove and replace the Hard Drive.
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn off the computer and turn it over.
  2. Slide the battery lock latch to the unlock position until it clicks into place.
    • Slide the battery lock latch to the unlock position until it clicks into place.
    • Slide and hold the battery release latch in the unlock position.
    • Slide and lift the battery out of the battery bay.
    • Slide the NEW battery into the battery bay until it clicks into place.
    • Slide the battery lock latch to the lock position.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the two screws from the computer base.
    • Slide the hard drive to the right to disconnect it from the connector on the system board.
    • Lift the hard drive out of the computer base.
    • Place the NEW hard drive on the computer base.
    • Push the hard drive towards the left to connect it to the connector on the system board.
    • Replace the two screws to the computer base.
Linea Traguardo
Terrence15
Membro da: 18/12/2017
70.258 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 65
