Salta al contenuto principale
Dell Inspiron 15 N5040 Battery Replacement
  1. Dell Inspiron 15 N5040 Battery Replacement, Turn off the Computer: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn off the computer and turn it over.
  2. Dell Inspiron 15 N5040 Battery Replacement, Sliding the Battery Latch: passo 2, immagine 1 di 1
    • Slide the battery lock latch to the unlock position until it clicks into place.
  3. Dell Inspiron 15 N5040 Battery Replacement, Sliding the Latch: passo 3, immagine 1 di 1
    • Slide and hold the battery release latch in the unlock position.
  4. Dell Inspiron 15 N5040 Battery Replacement, Removing the Battery: passo 4, immagine 1 di 1
    • Slide and lift the battery out of the battery bay.
  5. Dell Inspiron 15 N5040 Battery Replacement, Sliding the Battery: passo 5, immagine 1 di 1
    • Slide the NEW battery into the battery bay until it clicks into place.
  6. Dell Inspiron 15 N5040 Battery Replacement, Sliding the Battery Latch: passo 6, immagine 1 di 1
    • Slide the battery lock latch to the lock position.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 266
