Salta al contenuto principale
Dell Inspiron 15 M5030 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 15 M5030 Hard Drive Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard drive to the base of the computer.
  2. Dell Inspiron 15 M5030 Hard Drive Replacement, Sliding the Hard Drive: passo 2, immagine 1 di 1
    • Slide the hard drive away from the hard-drive connector on the system board.
  3. Dell Inspiron 15 M5030 Hard Drive Replacement, Lifting the Hard Drive: passo 3, immagine 1 di 1
    • Lift the hard drive out of the hard-drive bay.
  4. Dell Inspiron 15 M5030 Hard Drive Replacement, Placing the Hard Drive: passo 4, immagine 1 di 1
    • Place the NEW hard drive in the hard-drive bay and push the hard drive towards the connector until it is fully seated.
  5. Dell Inspiron 15 M5030 Hard Drive Replacement, Replace the Screws: passo 5, immagine 1 di 1
    • Turn the computer over and replace the two screws that secure the hard- drive to the base of the computer.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.131 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.986 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 153
