Introduzione
In this guide, we will be showing you how to remove and replace the Display Assembly.
Strumenti
Parti
Nessuna parte specificata.
Remove the two screws that secure the display assembly to the base of the computer.
Make a note of the Wireless Mini-Card antenna cable routing and disconnect the Wireless Mini-Card antenna cable from the Wireless Mini- Card.
Disconnect the display cable from the connector on the system board and remove it from the routing guide.
Remove the two screws (one on each side) that secure the display assembly to the computer base.
Lift and remove the display assembly out of the computer base.
Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
Route the display cable into the routing guide and connect the display cable to the connector on the system board.
Route the Mini-Card antenna cable into the routing guide and connect the Mini-Card antenna cable to the connector on the Mini-Card.
Turn the computer over and replace the two screws at the base of the computer.
