Salta al contenuto principale
Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement
Cosa ti serve
  1. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement, M.2 NVMe Solid State Drive: passo 1, immagine 1 di 2 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement, M.2 NVMe Solid State Drive: passo 1, immagine 2 di 2
    • Place the laptop with the bottom panel facing up.
    • Remove the single screw to access the bottom panel.
  2. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 2, immagine 1 di 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 2, immagine 2 di 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 2, immagine 3 di 3
    • Place a finger under the screw location and move it around the edge to pry the fourteen clips out.
    • There are six clips on each side of the panel and two on the edge by the screw.
    • Remove the bottom panel.
  3. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 3, immagine 1 di 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 3, immagine 2 di 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 3, immagine 3 di 3
    • Locate the M.2 drive to the right of the battery, below the hard drive.
    • Remove the screw on the edge of the drive.
  4. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 4, immagine 1 di 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 4, immagine 2 di 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 4, immagine 3 di 3
    • Lift up on the edge of the drive where the screw was.
    • Grab the drive by the two long edges.
    • Pull the drive out.
    • Note the keying on your new drive; it will only go in one way.
  5. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 5, immagine 1 di 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 5, immagine 2 di 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 5, immagine 3 di 3
    • Angle the new drive and insert it into the slot.
    • Apply pressure down on the screw end of the drive.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 36
Tutti i Tempi: 3,041
