Salta al contenuto principale
Dell Inspiron 15 Gaming 7577 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 15 Gaming 7577 Display Assembly Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the two screws (M2.5x5) that secure the display hinges to the palm-rest assembly.
  2. Dell Inspiron 15 Gaming 7577 Display Assembly Replacement, Open the Display Hinges: passo 2, immagine 1 di 1
    • Open the display hinges at an angle of 90 degrees.
  3. Dell Inspiron 15 Gaming 7577 Display Assembly Replacement, Lifting the Palm-Rest Assembly: passo 3, immagine 1 di 1
    • Lift the palm-rest assembly off the display assembly.
  4. Dell Inspiron 15 Gaming 7577 Display Assembly Replacement, Display Assembly: passo 4, immagine 1 di 1
    • After performing the above steps, you will be left with the display assembly.
  5. Dell Inspiron 15 Gaming 7577 Display Assembly Replacement, Placing the Palm Rest: passo 5, immagine 1 di 1
    • Place the palm-rest assembly on the display assembly.
  6. Dell Inspiron 15 Gaming 7577 Display Assembly Replacement, Close the Display Hinges: passo 6, immagine 1 di 1
    • Close the display hinges at an angle of 90 degrees.
  7. Dell Inspiron 15 Gaming 7577 Display Assembly Replacement, Replace the Screws: passo 7, immagine 1 di 1
    • Replace the two screws (M2.5x5) that secure the display hinges to the palm-rest assembly.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,972
