Introduzione
In this guide, we will be showing you how to remove and replace the Display Assembly.
Cosa ti serve
Remove the screws that secure the display hinges to the palm-rest assembly and open the hinges to an angle of 90 degrees.
Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
Note the display cable routing and remove the cable from its routing guides on the palm-rest assembly.
Lift the palm-rest assembly at an angle off the display assembly.
Place the NEW display assembly on the palm-rest assembly.
Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
Replace the screws that secure the display hinges to the palm-rest assembly.
Route the display cable through its routing guides on the palm-rest assembly.
Route the antenna cables through its routing guides on the palm-rest assembly.
Un commento
I can't replace the cables on the left side of the lid through the hinge.
