Salta al contenuto principale
Dell Inspiron 15 7579 RAM (Memory) Replacement
Cosa ti serve
  1. Dell Inspiron 15 7579 RAM (Memory) Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 2, immagine 1 di 2 Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 2, immagine 2 di 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 RAM (Memory) Replacement, RAM (Memory): passo 3, immagine 1 di 1
    • Fold protective flaps to the side on the RAM module located in the upper right corner of the laptop.
  4. Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 4, immagine 1 di 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 4, immagine 2 di 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use the tweezers to push the crimping metal away from the chip. The chip will pop up into an angled position.
    • Remove the chip by pulling at the same angle as the chip with the tweezers.
  5. Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 5, immagine 1 di 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 5, immagine 2 di 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 5, immagine 3 di 3
    • Fold the plastic flap over on the other side.
    • As before, pull the fasteners away from the chip with the tweezers.
    • Remove the chip by carefully pulling it out with the tweezers.
  6. Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 6, immagine 1 di 2 Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 6, immagine 2 di 2
    • When reassembling, you must match the notch in the card with the notch in the connector header shown in red.
    • Doing otherwise will break the stick if forced.
Conclusione
Cal Poly, Team S24-G9, Maness Spring 2018 Membro di Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 865
