Salta al contenuto principale
Dell Inspiron 15 7579 Display Replacement
Cosa ti serve
  1. Dell Inspiron 15 7579 Display Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Display Replacement: passo 2, immagine 1 di 2 Dell Inspiron 15 7579 Display Replacement: passo 2, immagine 2 di 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Display Replacement, Fan: passo 3, immagine 1 di 2 Dell Inspiron 15 7579 Display Replacement, Fan: passo 3, immagine 2 di 2
    • Remove the two 7.9 mm screws from the fan with a Phillips #0 screwdriver.
  4. Dell Inspiron 15 7579 Display Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15 7579 Display Replacement: passo 4, immagine 2 di 2
    • Unplug the wires from the port.
    • Be sure to pull from the plastic connector, not the wires.
  5. Dell Inspiron 15 7579 Display Replacement: passo 5, immagine 1 di 1
    • Carefully lift the fan out of the computer.
  6. Dell Inspiron 15 7579 Display Replacement, SSD M.2 Drive: passo 6, immagine 1 di 1
    • Remove the single 3.6 mm screw holding the left side of the M.2 SSD card with a Phillips PH0 screwdriver.
  7. Dell Inspiron 15 7579 Display Replacement: passo 7, immagine 1 di 1
    • Gently pull out the SSD card at the angle it is relaxed in to remove it. It is easiest to do this by hand.
    • Be gentle when pulling the SSD card out. It should take little effort to get it to slide out properly.
  8. Dell Inspiron 15 7579 Display Replacement, Motherboard: passo 8, immagine 1 di 2 Dell Inspiron 15 7579 Display Replacement, Motherboard: passo 8, immagine 2 di 2
    • Remove the six 2.1 mm screws with the Phillips #0 screwdriver.
  9. Dell Inspiron 15 7579 Display Replacement: passo 9, immagine 1 di 2 Dell Inspiron 15 7579 Display Replacement: passo 9, immagine 2 di 2
    • Unplug the eight ribbon cables connected to the motherboard.
  10. Dell Inspiron 15 7579 Display Replacement: passo 10, immagine 1 di 1
    • Lift the motherboard up from the side opposite of the external ports and remove it from the laptop.
  11. Dell Inspiron 15 7579 Display Replacement, Display: passo 11, immagine 1 di 2 Dell Inspiron 15 7579 Display Replacement, Display: passo 11, immagine 2 di 2
    • Remove the screw that holds the Wi-Fi card in place with a Phillips #0 screwdriver.
    • Disconnect the black and white coaxial cables from the Wi-Fi card.
    • Remove the Wi-Fi card from its port.
  12. Dell Inspiron 15 7579 Display Replacement: passo 12, immagine 1 di 2 Dell Inspiron 15 7579 Display Replacement: passo 12, immagine 2 di 2
    • Remove the two screws from the metal plates with the Phillips #0 screwdriver.
  13. Dell Inspiron 15 7579 Display Replacement: passo 13, immagine 1 di 3 Dell Inspiron 15 7579 Display Replacement: passo 13, immagine 2 di 3 Dell Inspiron 15 7579 Display Replacement: passo 13, immagine 3 di 3
    • Lift up the two hinges perpendicularly to the board beneath it.
    • It may be difficult to lift up the hinges, so it may take some force to remove them.
    • Lift up on the keyboard at an angle from the laptop and gently pull away from hinges.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,102
