Salta al contenuto principale
Dell Inspiron 15 7579 Battery Replacement
Cosa ti serve
  1. Dell Inspiron 15 7579 Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Battery Replacement: passo 2, immagine 1 di 2 Dell Inspiron 15 7579 Battery Replacement: passo 2, immagine 2 di 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Battery Replacement, Battery: passo 3, immagine 1 di 2 Dell Inspiron 15 7579 Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
  4. Dell Inspiron 15 7579 Battery Replacement: passo 4, immagine 1 di 1
    • Pull out the fabric clip that attaches the battery to the main board from the connector by hand.
    • Remove the battery from the device.
    Super easy 3minute battery swap, removing and replacing housing screws is what all the work here is.
    My Mom is super happy she no longer has to be plugged in to use her laptop.
    Thank you ifixit 😊✌️
    That1HippieChick - Replica
Conclusione
Altre 7 persone hanno completato questa guida.
Cal Poly, Team S24-G9, Maness Spring 2018 Membro di Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Membri
6 Guide realizzate
2 Commenti
Thanks! Very helpful and to the point!
You ARE TECHNICALLY missing one step however, removing the fabric ribbon from the old battery at the end. Yes, it seems like common sense but…
Anyways, thanks.
Thomas Keats - Replica
Thanks for the help, worked well.
Remember the connector needs to be removed from the old battery and re-installed in the new. I used a small slotted screwdriver.
A. Holness
June 7, 2020
andrew.w.holness - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 32
Tutti i Tempi: 6,784
