Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide will lead you through the process of removing the back panel of the Dell Inspiron 15 7579 to access the internal components.
Parti
Nessuna parte specificata.
  1. Remove the ten 7.9 mm screws with the Phillips #1 screwdriver.
    • Remove the ten 7.9 mm screws with the Phillips #1 screwdriver.
  2. Insert metal spudger into a gap in between the back panel and the back of the screen. Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
Conclusione
Inaki Madrigal
Membro da: 23/04/2018
715 Reputazione
6 Guide realizzate
Cal Poly, Team S24-G9, Maness Spring 2018 Membro di Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 740
