Salta al contenuto principale
Dell Inspiron 15 7579 2-in-1 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 15 7579 2-in-1 Display Assembly Replacement, Turn the Computer Over: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Turn the computer over and open the display to 180-degree angle.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  2. Dell Inspiron 15 7579 2-in-1 Display Assembly Replacement, Place the Computer: passo 2, immagine 1 di 1
    • Place the computer on a flat surface with the display facing down.
  3. Dell Inspiron 15 7579 2-in-1 Display Assembly Replacement, Remove the Screws: passo 3, immagine 1 di 1
    • Remove the screws that secure the display assembly to the palm-rest assembly.
  4. Dell Inspiron 15 7579 2-in-1 Display Assembly Replacement, Lifting the Display Assembly: passo 4, immagine 1 di 1
    • Lift the display assembly off the palm-rest assembly.
  5. Dell Inspiron 15 7579 2-in-1 Display Assembly Replacement, Align the Screw Holes: passo 5, immagine 1 di 1
    • With the display facing down, align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  6. Dell Inspiron 15 7579 2-in-1 Display Assembly Replacement, Replace the Screws: passo 6, immagine 1 di 1
    • Replace the screws that secure the NEW display assembly to the palm-rest assembly.
    • Turn the computer over and close the display.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.161 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,671
