Salta al contenuto principale
Dell Inspiron 15 7560 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 15 7560 Display Assembly Replacement, Note the Routing: passo 1, immagine 1 di 1
  2. Dell Inspiron 15 7560 Display Assembly Replacement, Open the Latch: passo 2, immagine 1 di 1
    • Open the latch and disconnect the display cable from the system board.
  3. Dell Inspiron 15 7560 Display Assembly Replacement, Open the Display: passo 3, immagine 1 di 1
    • Open the display at an angle of 90 degrees.
  4. Dell Inspiron 15 7560 Display Assembly Replacement, Placing the Computer: passo 4, immagine 1 di 1
    • Place the computer on the edge of a table so that the palm rest and keyboard assembly is on the table and the display assembly extends past the table edge with the display hinges facing up.
  5. Dell Inspiron 15 7560 Display Assembly Replacement, Remove the Screws: passo 5, immagine 1 di 1
    • Remove the four screws (M2.5x5) that secure the display hinges to the palm rest and keyboard assembly.
  6. Dell Inspiron 15 7560 Display Assembly Replacement, Lifting the Display Assembly: passo 6, immagine 1 di 1
    • Lift the display assembly off the palm rest and keyboard assembly.
  7. Dell Inspiron 15 7560 Display Assembly Replacement, Placing the Assembly: passo 7, immagine 1 di 1
    • Place the palm rest and keyboard assembly on the edge of a table with the keyboard facing down.
  8. Dell Inspiron 15 7560 Display Assembly Replacement, Align the Screw Holes: passo 8, immagine 1 di 1
    • Align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
  9. Dell Inspiron 15 7560 Display Assembly Replacement, Replace the Screws: passo 9, immagine 1 di 1
    • Replace the four screws (M2.5x5) that secure the display assembly to the palm rest and keyboard assembly.
  10. Dell Inspiron 15 7560 Display Assembly Replacement, Close the Display: passo 10, immagine 1 di 1
    • Close the display and turn the computer over.
  11. Dell Inspiron 15 7560 Display Assembly Replacement, Sliding the Display Cable: passo 11, immagine 1 di 1
    • Slide the display cable into the connector on the system board and close the latch to secure the cable.
  12. Dell Inspiron 15 7560 Display Assembly Replacement, Routing the Antenna Cables: passo 12, immagine 1 di 1
    • Route the antenna cables through the routing guides on the fan.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Terrence15
Membro da: 12/18/17
79.131 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.986 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 948
