Introduzione
In this guide, we will be showing you how to remove and replace the Battery.
Parti
Nessuna parte richiesta.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
  2. Peel the tape that secures the hard-drive cable to the battery.
    • Peel the tape that secures the hard-drive cable to the battery.
  3. Open the latch and disconnect the hard-drive cable from the system board.
    • Open the latch and disconnect the hard-drive cable from the system board.
  4. Remove the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
    • Remove the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
  5. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  6. Lift the battery off the palm rest and keyboard assembly.
    • Lift the battery off the palm rest and keyboard assembly.
    • Press and hold the power button for five seconds to ground the system board.
  7. Align the screw holes on the NEW battery with the screw holes on the palm rest and keyboard assembly.
    • Align the screw holes on the NEW battery with the screw holes on the palm rest and keyboard assembly.
  8. Replace the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
    • Replace the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
  9. Slide the hard-drive cable into the connector on the system board and close the latch to secure the cable.
    • Slide the hard-drive cable into the connector on the system board and close the latch to secure the cable.
  10. Adhere the tape that secures the hard-drive cable to the battery.
    • Adhere the tape that secures the hard-drive cable to the battery.
  11. Connect the battery cable to the system board.
    • Connect the battery cable to the system board.
Linea Traguardo
Terrence15
Membro da: 18/12/2017
70.653 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 80
Tutti i Tempi: 622
