Introduzione
Use this guide to replace the motherboard within your Dell Inspiron 15 5584 laptop.
The motherboard is a piece of hardware that acts as a "hub" for all the other components. A motherboard is a circuit board that connects all other components to the processor, distributes electricity from the battery, and contains connectors for device storage. Furthermore, the motherboard allows for external devices such as keyboards, flash drives, mice, etc. A faulty motherboard can cause the computer to become nonfunctional or unresponsive.
Before tampering with the device, ensure the battery is drained and the device is shut off. Furthermore, exercise caution when dealing with the motherboard; it is fragile and easy to break.
Cosa ti serve
Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
Lift up the motherboard ribbon latch using a pair of tweezers.
Gently lift the ribbon cable from the motherboard connector socket.
Remove the three 6 mm screws holding down the screen hinge in the upper right corner using a JIS #0 screwdriver.
Loosen the four captive 3.5 mm screws securing the heat sink to the motherboard using a Phillips #0 screwdriver.
Remove the CPU plate cover from the motherboard and safely place it off to the side.
Remove the single 3 mm screw that holds down the Wi-Fi card using a Phillips #0 screwdriver.
Remove the Wi-Fi card from the motherboard.
Using tweezers, detach the connector found near the SSD.
Un commento
This guide is absolutely needed for the replacement of Dell Motherboard. Thanks for sharing.
