Introduzione
In this guide, we will be showing you how to remove and replace the Hard Drive.
Parti
Nessuna parte richiesta.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer.  After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Using the pull tab, disconnect the hard-drive cable from the system board.
  2. Peel off the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
    • Peel off the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
    • Note the hard-drive cable routing and remove the cable from the routing guides.
    • Remove the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
    • Lift the hard-drive assembly along with its cable off the palm rest and keyboard assembly.
    • Disconnect the interposer from the hard-drive assembly.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
    • Lift the hard drive off the hard-drive bracket.
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
    • Replace the screws that secure the hard-drive bracket to the hard drive.
    • Connect the interposer to the hard-drive assembly.
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
    • Replace the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
    • Route the hard-drive cable through the routing guides on the palm rest and keyboard assembly.
    • Connect the hard-drive cable to the system board.
    • Adhere the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
Linea Traguardo
Terrence15
Membro da: 18/12/2017
70.258 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 28
Tutti i Tempi: 146
